Looking for Stereo Wiring Diagram
JClark
2001 Buick Century Limited
Hi All!
My factory head unit (AM/FM/CASS/CD) has finally decided to call it quits, and I just so happen to have an old Sony aftermarket unit lying around to put in its place. The only problem I seem to be having is finding a pinout or wiring diagram to wire up the necessary radio adapter. My 2001 Century is equipped with the Concert Sound III 6-speaker setup with a factory amplifier in the trunk, and uses the 32-pin blue connector. I plan on keeping the factory amplifier, I just want to swap out the factory head unit with an aftermarket one.
Does anyone happen to have, or know where I can find, the pinout of the 32-pin connector for the radio side?
Thanks in advance!
~Justyn C
1,137
You may want to check Scosche, Metra or PAC GM interface wiring harness kits as no hardwiring into the original harness is needed just the replacement stereo. Check Crutchfield as what is available for your vehicle.
Bullymong88
East Tennessee
Century Limited
I used a metra wiring adapter and soldered the ends to my pioneer plug 7 years ago its worked flawlessly ever since
Edit. I bought the adapter at Walmart for like 5-10 bucks
