- 2,149
- 113
- 2007 Lucerne CXL. and 1995 Lesabre currently, past 1973 Riviera, 1968 Riviera
The STB is installed on a 2007 3.8L. These are available from Pontiacs see the link below for the GM part#, these show up on Ebay $50-70.
Pontiac Bonneville - H SHEET METAL/FRONT END > EPC Online > Nemiga.com
Parts needed
#21 - 4 needed
#69 - 1 needed
#70 - 6 needed
#71 - 2 needed LH & RH
See photos on clearance, I did try a mock up with the engine cover and it appeared that it would clear. This is a perfect match and all points line up, simply remove strut bolts, line up mounts, use new strut bolts loose, line up center and install bolts loose and once every thing is in tighten to spec. Extremely easy upgrade to tighten up the Lucerne.
Parts needed
#21 - 4 needed
#69 - 1 needed
#70 - 6 needed
