MAP Sensor Code P0107
Merkava_4
5.7L LS1 Member
559
Clovis, CA
2000 Buick LeSabre
It's a simple 3-wire connector. Grey for 5V reference, green for signal to the PCM, and orange w/ black stripe for ground. All 3 wires check out fine, but obviously the PCM thinks the voltage signal it's receiving is too low. No drivability issues whatsoever. I cannot find any vacuum leaks. I'm thinking about ordering a new MAP sensor and pigtail, but wanted to see what you guys think first.
181
Most common problem with the MAP sensor is the vacuum connection to the MAP, or the mount seal.
