mix and match tires
thezeeman333
2002 Rendevous
I looked through the search and couldn't find anything on mix and match tire.
I have an 02 with AWD.
Here are my tires:
Front left - Michelin XLT with 6/32 tread
Front right- Michelin XLT with 3/32 tread
Back left - Michelin XLT with 7/32 tread
Back right- No name tire with tread pattern very close to Michelin XLT- 8/32 tread
All tires are 215/70/16 All season.
I obviously have to replace the front right tire, which leads me to my questions:
Can I buy just one tire? Can I mix and match tires the same size, but different brands or treads without messing with the awd?
Any help or suggestions would be appreciated.
Staff member
5,600
890
Replace the two front tires, should have similar remaining thread and pattern on each end of vehicle.
TollKeeper
15
Brighton, CO
If you replace just one, you could be asking for problems. On ANY AWD vehicle, you should replace all tires at the same time. You could end up damaging the rear diff, the PTO, or the front diff.
If money is the issue, I would take the front left, and match it to the back left (both Michelins on the rear diff), and replace the front.
Of course that means putting new Michlelin XLT tires on the front. Which come with a factory tread depth of 10.5. Its nearly half of what those 2 other tires would have. This is asking for trouble. I would not suggest doing it.
If it were me, I would go buy all new tires.
You can get a decent set of tires from Discount Tire for about 600 bucks installed. (I had these installed on my Rendezvous, my Envoy, and I am putting another set on my Envoy tomorrow. Best tires ever IMHO)
Cheap ones for about 300. (I have these on my Aztek, decent tire, not great, just decent)
thezeeman333
2002 Rendevous
thanks for the suggestions but yes money is a big issue right now. Can't afford new tires and trying to find 4 used of the same brand with same tread thickness is tough to do.
thezeeman333
2002 Rendevous
I gave in and bought 4 new Hankook tires and two new OEM steel rims. Got them Road Force balanced and the guy said the tires and rims were perfect. I had a shake with the other tires and was told 2 rims were bent. I just took it out for a drive and the car still shakes between 30 and 50mph. Already replaced rotors and pads, struts and shocks, sway bar and links, and rebuilt calipers. I have no idea why it still shakes at those speeds. Its not as bad as before but I can still feel it which is bugging me to no end. :(
thezeeman333
2002 Rendevous
I noticed a bushing on the front control arm is beat up a bit. Could this be a reason the suv is shaking? I sometimes hear a clunking sound when turning or over a bump. I did the ball joint test by grabbing the wheel and rocking it back and forth. It seems solid on both front wheels.
TollKeeper
15
Brighton, CO
It could be a CV joint, a axle U-Joint.. The other rhings you already replaced, tires and wheels. Brakes will only cause a vibration/shake under braking. and a control arm/control arm bushing will only cause alignment issues.
The only other thing I can suggest is try moving the wheels that are on the front axle, to the rear, and vice versa. See if the vibration moves with the the tire/wheel location.
thezeeman333
2002 Rendevous
Thanks. I will try moving the wheels around. I quickly looked at the CV joint and the rubber is good all around. I will check axle u-joint when I change tire locations.
