Motor mounts
Quent38
06 Lucerne
2006 Lucerne North Star engine break in power steering high pressure hose caused by bad motor mounts
647
Both V8 an V6 mounts are known to have to be replaced as it's a oil filled mount to isolate engine vibration from the rest of the car. Milage in the 50 to 60k range have had them needed to be replaced so it's something that each car can be different. You may want to also check out the Cadillac DTS forum as it's primarily the same car with the same mount design.
