Mute button
SpencerK
130
Regal TourX
I just discovered that if you push (but don't hold) the power off button in the middle of the volume dial it mutes the volume. Maybe you all know that, but I didn't! So maybe somebody else would like to know that.
D2R
671
Michigan
2019 Regal TourX Essence
Or press the button that muted the system one more time.
One more thing I noticed between the older vs the newer UI with this power button.
When I short-pressed the power button to mute the volume, the older UI simply mutes but does NOT pause the music.
The newer UI mutes AND pause the music.
Hunter Mike
326
America’s Dairyland
RTFM
G-685947
How do you unmute it
G-195578
My volume button somehow muted yesterday. I have tried everything! Even my blinkers won't make noise. It happened while I was driving so I panicked and started pushing buttons. I tried all settings. Is this a fuse? Loose wire? 2018 Buick Encore. Help!
Stubby
11 Buick enclave
I'm having the same issue
Jack GS
835
93
Metro Detroit
2019 Regal GS
And I can't figure it out it's been bothering my wife so much I need help
This will come off as a joke, but I am completely serious... have you tried disconnecting the battery and connecting it back up after a while?
Cars are rolling computers nowadays and sometimes they just need a good old hard reset. This has corrected various odd symptoms others have had.
D2R
671
Michigan
The blinker sound comes from the speakers.
It could be the amplifier or speakers that has issues or the fuses/relays.
Amct15
37
2020 Regal GS
As per Anaduff, check fuse F16. When I pulled this fuse for a test, I had no radio audio and no turn signal clicks. Appears to power the audio amplifier.
On closer examination--looks like you need to pull F16 on the cabin fuse block...
