Need help please
Jeff_neitzke
My Buick verano for some reason is all in kilometers and the menu to switch it back to mph is gone the tire pressure is also in kilometers is there a way to reset the dic or re boot the dic to reset. I tried disconnecting the battery and letting it sit and nothing. Please help not sure what else to do.
1,978
What happens when you press the Set/Clear button?
Jeff_neitzke
Was trying to avoid going to the deal do to cost.
Jeff_neitzke
Just to be clear, you are first pressing the Menu button , then twisting the thumb wheel to get to the Vehicle Information Menu?
Yes it shows tire pressure in kilometers and some fuel thing in kilometers but the unit to switch back is no longer there for some reason. So I'm trying to see if there is some way to reset the dic to see if it comes back
1,978
When you press the menu button you should have two choices. First menu is Trip Fuel Menu, next is Vechicle Information. You twist the thumb wheel to select which one. Are you selecting the Vechicle Information Menu?
