Need help with my 2013 Buick Verano
cwebbster00
Verano 13
I'm trying to bypass my factory amp and needing help on how to do it. I have replaced all door speakers and the center dash speaker. Also added 2 alpine type S 10s with 1500 watt amp. When I increase the volume and the bass hits it will shut off my amp. This is my last try before I rip it all out and freaking burn it. Please I hope someone can help.. maybe these pics will help idk
875
SE
With all those LITTLE wires, there is no way to produce 1500 amps in the sound system without failing & major wiring upgrades. You need to to take to a professional that may help.
G-342951
So your telling me I can't take a harness plug into my factory amp bypass it and plug into my aftermarket amp lol ok
13verano
2013 Buick verano Turbo
Are you using an aftermarket amp for the interior speakers or just a bass amp for the subs? If it's just a bass amp you're adding there should be no need to bypass, just use a quality line output converter such as the audiocontrol lc2i and tap into the rear deck speaker. What problems exactly are you having with it?
13verano
Also you should sand down the paint on that ground, I can't tell what gauge it is from the pictures but it looks at least 4awg, I personally would run 2 or 0 for 1500rms
