New caretaker of 08 Lucerne CXL
Curiousgb
08 Lecerne
I recently became the caretaker of my mothers 08 Lucerne. It has 95k on the odometer. Seems to be in very good shape. I did a good detail today. Replace the hood strut. Went to the auto parts store to get shocks and struts and the cruise control wouldn't work. Came home looked on this forum. Checked my brake lights and they are always on. Seems this is indicative of a bad switch. Easy enough, but now I find that it will need to be calibrated. Fun. 16736
1,101
Welcome and yes unfortunately many newer vehicle replacement components may need calibration. With that being said some items may be replaced and can work out of the box, so it's a try and see. As you dig around the most common problem is the rear seat fuse box and relay for the fuel pump so check if that's been done, other than oil, transmission and coolant change along with wires and plugs you should be good to go if it hasn't had these done yet.
Curiousgb
08 Lecerne
I guess I got lucky. I thought it was coincidence that the brake sensor died after I changed the battery. So I opened her up and pulled the plug to the sensor. I then turn the key to the on position and plugged it back up. Brake lights were out. Pressed brake pedal lights came on, but stayed on, (grumble). Turned key off, unplugged brake sensor. Turn key on, press brake pedal, plug up sensor, release brake pedal. Lights are now off and they come on when I press the pedal, and go off when I release. And the cruise works. Yea
1,101
Glad it worked, some days it's better to be lucky then good LOL.
sandman900ss
One bit of advice to the new member on this car: do NOT pull the door handle hard by mistake when it's locked. You'll pull the handle off the door as it's made of plastic, not metal, and the self tapping screws rip out. Not fun taking the door apart to replace the handle with another plastic one. Unbelievable GM cost cutting!
Curiousgb
08 Lecerne
Hello, were you able to get someone other than Buick to recalibrate it?
Yes, my work mechanic had a snap on test set. He didn’t know what I was talking about but we found the settings and bam good as new. What crappy design.
