OBD1 codes explanations
Frago
Park Avenue 1991
Hello to all
I started to work on my PA and I have these codes :
- 26 : QDM A circuit #1 fault
- 31 : Wastegate solenoid circuit fault
- 44 : Oxygen sensor lean mixture
Can anybody give me some explanations about these faults and maybe what to do ? Where to start...
Regards
Frago
634
You need to find out what item is being driven by the Quad Driver that set the code. This code usually sets when there is a voltage fault on a particular Quad Driver due to a bad relay, solenoid, wiring or whatever is being run off that driver.
Code 26
2 flashes, pause, 6 flashes
Quad Driver Circuit Have the car checked by a dealer
Code 31
3 flashes, pause, 1 flash
Park/neutral switch Check all connectors, and for a faulty switch
Code 44
4 flashes, pause, 4 flashes
Lean Exhaust Check the ECM wiring connections. Check for vacuum leaks at the hoses and intake manifold gasket
Example of quad driver circuit shown below.
Frago
Park Avenue 1991
Hello HotZ28
Tandis
Code 26
Code 31
Code 44
Hello HotZ28
Thanks for these explanations. Where did you find the troubles codes list? The one I used was different and yours seems to be more pertinent than mine...
I will start to work on this😉
Thx again
634
Hello HotZ28
Tandis
Hello HotZ28
Thx again
I forgot where the code descriptions I posted originated since they have been stored on my HD for years. A good source for manufacture & year/VIN specific OBD1 codes are listed in the links below. Since I do not know if your car is an VIN-L, or VIN-C, I will include both. Good Luck!
Frago
Park Avenue 1991
[/URL]
[/URL]
Hello HotZ28
Thanks again for these attachments...
How do I know that my PA is a L or a C model ?
On the registering card ? In the VIN ?
Regards
Frago
LARRY70GS
200
Oakland Gardens, N.Y.
98 Riviera, 70 GS455 Stg1
Frago
Park Avenue 1991
Thx to both of you...👍
Regards from France🇫🇷
