Optispark distributor
Lucabrazzi1
1994 Roadmaster Estate Wagon
This is my first ever forum so bear with me. I have a 1994 Roadmaster Estate Wagon with the LT1 engine. Real garage kept gem from my neighbor. Total enjoyment for 18 months. Until this May. My mechanic had to replace my optispark. He put two aftermarket ones and he still can't get a spark to cylinder #3. He replaced the ignition coil and the ignition module still not luck. He ran a diagnostic on his computer and the OBD I is fine. He tried to get an OEM Optispark but can't find one. Any ideas on where to get a quality replacement or an original? Or any ideas on why one cylinder is not getting the spark?
Thanks
845
Hopefully someone this forum will respond with additional information, but there are a few LT1 related forums also check out the Chevrolet forums as they may have more information on this motor. Good luck on getting the problem corrected.
Lucabrazzi1
Thank You
326
The Optispark failure is often misdiagnosed and could be the result of ignition wire failure, spark plugs, or many other problems. I have owned many Optispark cars (Corvette, Z-28's & RMS) some vented and not. I see no mention of whether the plugs/wires were replaced during that Opti replacement? If an Opti/wires actually fail to deliver spark, the plugs will foul and not fire. Inspection of the wires & plugs should lead to the conclusion of this mystery.
Lucabrazzi1
Thank you for your help. The plugs and wires were all replaced a year ago but I will ask if he checked the wires
Lucabrazzi1
Lucabrazzi1
Thank You. Another new distributor and an AC Delco ignition coil. Starts and runs great. But...when it gets hot it starts to hesitate when he puts a load on it like going up a hill. He also changed the plugs and wires. At least all 8 cylinders are firing.
