Passenger air filter
Rockyrr
Casacada566
I have a 2017 Cascada. The manual refers to a passenger air filter that's replaceable. Where is it and how do you change it?
Thanks,
Rocky
Staff member
5,085
782
You change it at 22,500 miles or 2 years which ever comes first and it appears to be a highly guarded secret as to where and how. Typically they are behind the glove box but cannt find the instructions anywhere.
Curler55
Cascada
I read the file and removed the 4 screws shown but the glovebox would not move on my 2016 Cascade. Has anyone tried replacing the cabin filter themselves?
Richard Morgan
2016 Buick Cascada
Thanks,
Rocky
It’s behind the glove box. You have to remove the air bag the tight side panel and the glove box to access the filter compartment. The process isn’t easy. About 15 screws to remove.
JoeBo
Cascada
I removed the air bag and the four bolts holding the glove box frame and it still will not come lose. There is one bold under the right hinge that I'm trying to remove and it seems to be looser but still does not want to come out. Does the air bag tray come out with the glove box?
JoeBo
Cascada
If anyone is still having this issue the manual left our one step. Once you remove the passenger knee air bag then you must remove the three screws from the tray where the air bag was mounted. I used a TORX 10H which seemed like a really small bit for such a large head screw. After that you remove the four screws on the glove box frame and the glove box come out with ease.
Oliver H
2016 Cascada
Really
Where can I find the instructions to remove the passenger knee Airbag?
(I see 2 large screws when looking up.....from the floor......are the screws I need to remove 1st?)
Do I need to do anything special..... related to the Airbag......so I don't get an accidental Airbag deployment?
Thanks,
kurtp13
7
Cascada
This is a good video and is exactly how I did it.
The 3 screws that are mentioned as being under the knee air bag are required to come out. They are fastened into the glovebox.
Removing the air bag is the only way I saw to get out the glovebox. I didn't want to take it out either but it doesn't have to be disconnected, only dropped out of the way to expose the 3 lower glovebox attachment screws. Cascada Glove Box - 3 lower fasteners.jpg
acwjr11
Cascada
I was at my dealer today and had them print a copy of the instructions. It is behind the glove box but the door, bin and frame have to be removed with the mounting screws. I have only had to remove the door itself in my past experience with these. I am attaching the instructions as a file.
files are incomplete...... only 4 pages downloaded , is that all? Or did I do it wrong? I have the air bag out 7 screws out and the fkn thing still won’t budge! Arrrgggggggghhhhh.
kurtp13
7
Cascada
There are only 4 pages to the manual. It's not that descriptive. The video is much better. I posted the picture of the 3 screws under the glove box so those less obvious ones would be highlighted. But once you get the 4 in front and the additional 3 it should be somewhat easy.
acwjr11
Cascada
yup I took a break, then tried again...... it was those damn 3 screws hidding under the glove box that got me! Thanks.
