PAU door locks, windows, mirrors not working
Failuer
2000 PAU
Hi all!
I’ve got a 2000 Park Avenue Ultra. As mentioned in the title I’m having some issues with my locks and windows.
Symptoms:
  • No controls (windows or door locks) anywhere in the car work
  • Door chime does not work
  • Radio does not turn off when the door is open but does turn off after 10 min or so
  • Door locks operate normally with a key
  • Trunk opens with in car switch and remote
So far I have
  • Removed the DDM and reseated all connections
  • Verified 12v at red wire on 4 pin connector and orange and yellow? wires on the 20 pin (pin 11 and 12 I think)
  • Verified rear fuse and under hood fuses are in tact
I’m running into a bit of a dead end and was wondering if anyone had any tips or anything else to look for.
Thanks for the help!
Alan 55
305
98
Florida
Hi all!
Symptoms:
So far I have
You did not mention checking and cleaning all ground connections associated with the non working items. This may require a wiring diagram or a FSM for your vehicle. You have done some good work so far but I would now turn to the grounds. All electrical systems on your vehicle require power and ground.
Drakito
77
Southern Utah
2003 Park Avenue Ultra
The driver door latch wears out. It has the door pin built into it. If the latch is not reading correctly the BCM thinks either the door is always closed, or always open. Even if the door has different states of open and closed.
Quick check on this is to open the passenger front door and see if the radio turns immediately off after the key is cycled.
Secondary issue is the drivers door boot can have wires broken from age and wear, cutting all signals to the main controller.
If you have any aftermarket radios or accessories powered from behind the radio installed sometimes the installer accidentally grounds to a data line and kills the data systems until the ground is removed.
Failuer
2000 PAU
To close the loop on this I did go ahead and verify the grounds were good. I ended up picking up a driver door module (DDM) from eBay and swapped it in. Everything is currently mostly working again. No flashing of firmware was needed.
I now have a problem where all controls on the drivers side do not work but do appear to have power (all switches light up at night). I’m wondering if this is what fried the previous DDM...
Alan 55
305
98
Florida
Thanks for your follow up message. Keep us posted on new developments.
