Performance
93 roadmaster estate wagon
Have a 93 roadmaster wagon looking for performance suggestions has corvette 350 headers b&m shift kit hei ignition distributor wires and mad coil 3:73 locker rear diff dual exhaust is hooked up properly through factory wiring and ecm anything else I can do for more power and performance
255
Assuming the distributor has weights and springs, is the curve modified to give you full advance by 2,800 rpm with a total of 36 degrees?
