PN for engine block heater needed
94cruiser
399
52
not yet
Tried several gm parts online sites and I’m unable to find the engine block heater kit assembly.
Does anyone have the part number?
94cruiser
399
52
not yet
Can someone confirm if this is correct:
Cord
part number: 84110726
Plug
part number: 12586687
94cruiser
399
52
not yet
I did. That's the part number they gave me, but when I check online the plug states it does not fit 2018 TourX...
Rhetoric
725
93
MPLS
Red Needle TourX
I have one from the factory. Its a Philips-Temro unit that only works when the temp is below 0F. I can try to see if it has a P/N.
94cruiser
399
52
not yet
So what did the dealer say about it not matching?
I called few local dealers and one of them gave me that part number.
When I plug it in to those online GM parts websites some say it is compatible with 2018 TourX and some say it's not.
94cruiser
399
52
not yet
It's my understanding the temperature sensor is at the 110 outlet and all that's needed is to cut the cord and put a new end on it.
I would be happy with an outlet on a timer and use it when temperature hits 20F.
Rhetoric
725
93
MPLS
Red Needle TourX
You are correct. Even better, since you are sourcing new just get a cord without the temp sensor from P-T. The connection on the freeze plug heater is not proprietary.
