Power door lock chimes instead of working
grifter77
Rainier 2004
On the drivers side door when I attempt to lock the doors using the power locks before I get out the system makes a single chime and doesn't lock the doors.
when I do it from the passenger side the doors lock, and no chime.
grifter77
Rainier 2004
I found the information but here's my issue I don't have the keyless entry fobs.
And they are required to turn it off.
I bought a replacement set but the car won't go into programming mode. I even took it to a locksmith and he couldn't get it to go into programming.
Is there a fuse or option that would stop it?
If I can program the fobs then I can turn off the lock
Staff member
5,085
782
Did look at page 210 of the 2007 manual, I dont see what year your car is.
There is no need for a FOB to use the customization menu.
Did you check with the supplier of the FOB if it is the correct FOB and how they recommend programming it.
grifter77
Rainier 2004
I have a 04 Rainier. Everything I have read requires the fob to change the settings but I will check the dash menu tonight.
Any ideas on what would cause the unit not to go into programming mode?
grifter77
Rainier 2004
got the fob fixed I will try to disable it to se if that fixes the issue
