Radio settings changed to Cadillac after blower motor resistor replacement
niccolemarie13
2010 Buick LaCrosse CXS
I just changed my heat a/c blower motor and the resistor (on 11/23/18) and now when I start my car the Cadillac emblem comes up on the radio screen and the screen colors are dark blue and red. It's also intermittent. If the Cadillac emblem shows it will switch to GM and then to Buick also the screen color does not change every time it shows Cadillac either. I have not yet disconnected the battery, I planned on it after work today. Is there a way to fix this without taking it to a shop?
L J
510
Regal TourX
If you have not disconnected battery yet, I would disconect for 5 minutes or so and see if that fixes problem.Of course you will lose all your presets on radio and any customization settings.
LJ
Rich B.
99
Minot, ME
Roger that on battery disconnect. Also unless exact replacement plug and play wires possibly cross-connected. Also possibly with unfiltered motor running creating distortion or interference with screen. I mean look at reception of digital free air TV during a thunder storm🤔
Blu05
171
27
Michigan
2005 Buick Lacrosse
That's a strange thing for the radio to display "cadillac" after replacing your heat/A/C resistor. I actually never heard of that happening before. Could it be BCM related? Or maybe something glitched after the repairs were made?
1,137
Assuming you didn't disconnect the battery while doing the repair it may have thrown a glitch. When disconnecting the battery a minimum of 10 minutes is needed to clear things out, timed auto shut down, and possibly pulling the radio fuse. Can't say this will fix the problem, but it's best guess.
Fcar1953
123
22
Pittsburgh Pa
You radio defaulted to a caddy program. I had a radio replaced in a Equinox i owned and when they loaded the program it came up cadillac. I had to return it to the dealer so they could reprogram to a chevy program. It is possible that the radio in that car was replaced with a caddy radio and it defaulted back. With the equinox XM had it as a caddy.
