Radio won't shut off.
bruker
We have an `02 CXL and the radio doesn't shut off even after the ignition is shut off and the key is removed. Any ideas as to what I can do to fix it?
rfranger
2006 Rendezvous 2013 Encore
It could be the the 10 minute retained power option. After you shut down and take out key you can still operate radio and power windows for 10 minutes or until you open the door.
guinnessfan
Anyone find the solution ? I'm still experiencing the same problem.
eswizz
The interior lights do not come on when I open the door. When I leave the lights on, there is no door chime either. Where is the door switch located? Is it an easy fix? Thanks!
typhoonk
my quess would be a broken wire in the door harness (rubber harness between door and car). Or worse case would be a bad door latch inside the door.
Tri5john
Palmyra ny
2002 Buick Rendezvous CXL
None of those are correct, it has a BODY CONTROL MODULE, it's in the center console under the dash...they are VIN number specific so one from a junkyard won't work
G-290950
I have the same problem...and it stays on even if I open and close the driver door
