Rattle in hood, possibly - this would be the 2005-2009 models
Globetrot1
LaCrosse CX, (2008) first gen, 3800 V6 Series III
My LaCrosse is a 2008. I never paid attention to the gap between the top of the fender and the edge of the hood on any car I've owned. Is it normal to see a little bit of upward and downward vibration of the hood at highway speeds and/or when there is a lot of wind while on the highway? It's minor but I didn't think there should be any.
I bring this up because, on suburban side streets, there can be some clanging/thumping sound when going over pavement gaps or badly damaged pavement and I don't recall this in the past. I bought the car new. What's a good way to test if I've got a hood that's banging around? What could cause it? The noise seems to come from way up high and I watch the hood lid when I go over some of these pavement gaps, assuming I'm on a side street and can allow myself to do that.
Have you had a noisy hood on this series of LaCrosse? Or any car? What was the fix?
Rich B.
95
Minot, ME
Would seem more likely an exhaust component has faltered and pipe(s) are banging. Sound as such in cars is very difficult to pinpoint source, non directional; at least the ones I’ve ran into.
If hood, try oiling hinges and make sure the main latch is lubed and not just catching on the second safety latch. Shouldn’t be any bounce to hood at all unless going over 100MPH?
Globetrot1
Are you thinking maybe loose heat shields or piping? With under 100,000 miles, my exhaust components seem to be working okay. A few people have poked around and can't find anything loose.
I'm debating whether to replace the first platinum plugs and plug wires. I just got about 30 mpg on a long road jaunt. However, it's got to be done sometime. The other thing is that spark plug wires usually start acting ornery much faster than do spark plugs.
The rest of this year's planned repair budget is for plugs and wires as well as a serpentine belt.
A banging and clanging sound on a Buick product is really unbecoming, even thought it's intermittent.
1,013
When you say "a few people" service shops? Strut tower, stabilizer bar, exaust hanger, engine mounts etc could all make a noise. On the hood with it fully closed, see if it will lift at both rear corners windshield side and in the front, no movement means it's closed. The only area that may have added turbulence is the underbody covers being loose.
Globetrot1
I was out of town for quite a while and wanted to respond sooner. Thanks.
I had new struts (all in ones) put on back in late spring on all 4 wheels. They were original and not as tight as they were 10 years ago. I still have the "same" rattle in the front left when it goes over bumps. As for the strut tower, are you thinking the upper mount at the top of the strut assembly, or would there be something else in the strut tower?
I'm guessing both a stabilizer bar and exhaust hangers could be checked from underneath.
Finally, as for the engine mount, this is new territory for me on a FWD car. We've had a lot of 3.8s and 3800s in the family. My dad had an early 80s Buick Regal sedan with the 3.8 that leaked oil but ran beautifully. I believe that the heated oil on the undercarriage eventually destroyed a motor mount. In a large parking lot, I could put one foot on the brake and the other lightly on the accelerator, and see the column mounted shift selector move slightly. I know that the engine mount had seen better days. What's a good way to test it or see it on a 3800 Series III V6, how many are there, and where are they located?
I'm almost thinking it's a bad strut assembly. That would be the easiest fix since the all in ones go in quickly. I had an independent shop do it. It rides beautifully on a nicely asphalted freeway but any secondary road with ripples makes things for the noise and jiggling sensation.
Pedal Commander
