Re Gearing
Julian1999
1970 Buick Skylark
Hello everyone! I own a 1970 Buick Skylark custom and I am looking to improve my 0-60 times, so I decided that I want to change out my car's rear end. The problem is, I am a college student with a budget (preferably $700 or below). I specifically want to run 4.10 or 4.11 gears. How would I go about finding an aftermarket rear end with these ratios? If a newer aftermarket differential is hard to come by for around the price I am hoping for, which truck rear ends would work that I could probably find at a local junkyard? Is it even worth it to buy a junkyard differential? And how will I make sure it will fit my Skylark?
Thank you!
Zeroboostbuick
430
S.W. Ontario Canada
Full disclosure... I don't know much about differential's.
But a set of new Ring & Pinion gears + labor shouldn't be more than your budget.
I've seen LSD ( not the psychedelic type ) Posi kits with ring n pinion + all the seals and bearings for about $ 700.
If you're doing the labor then definitely a Posi Kit would be the best. Having a Peg Leg is not cool.
:driving:
Staff member
5,768
918
You should step back a second and give some serious thought to what your primary driving is, highway, only local roads, and/or a lot of drag racing. What is the current ratio? Not so sure you can just buy a ring and pinion without considering the carrier you current have. Typically a 3 series carrier will not accept a set of 4 series gears without an adapter. Driving your car at highway speeds with a 4 series gear set will not be pleasant to you or your engine which I may assume is high mileage.
1,829
Here's a link to somewhat of what you are asking about. Unlike a Chevy rear ends it's a little more detailed on what or what not will work.
Buick Rear End Info
Thegoat
If you’re mostly street driven 3.73 will be a decent upgrade. I’m assuming the transmission is a TH350? Why not put a higher stall converter in it? That will help you 60 ft much better
LARRY70GS
239
Oakland Gardens, N.Y.
98 Riviera, 70 GS455 Stg1
Before you even think about changing the gears, you'll need to ID the rear in the car. Some 70-72 Skylarks came with a 12 bolt Chevy rear. If that is the case, parts availability will be excellent. On the other hand, if it is a 10 bolt, then parts availability may not be so good. The 10 bolt rear in a 68-70 Buick is most likely an 8.2. It's a pretty stout rear, but no one makes gears for it. In addition, if you currently have 2.56 gears in it, you'll need to change the carrier if you want a higher ratio. It will cost way more than 700.00 unless you can do all the install yourself. If it is done wrong, the gears will be noisy. It takes some specialized knowledge and measuring tools to do it right.
It might be easier to find a complete rear with the gears you want used. A Body rears (64-72 Chevelle, Skylark, Cutlass, Lemans) will pretty much bolt in with some minor differences in track width and drive shaft length.
If you are a college student and this is your daily driver, my advice is to leave it alone. After college, if you still have the car, then you can soup it up. Some advice from an old guy who was a young guy hot rodder once and has been there done that and sometimes learned the hard way.
Vicious2316
Western NC
2 Buick Turbo Regals (1986-1987), 2 Buick Regal GS 3800 Supercharged 1998-2000, 1987 Buick Century
Thank you!
These cars came with the performance option of 3.42 rear and really seem to do well on the street and track with the torque these cars produce.
Vicious2316
Western NC
It would also help to know the engine and transmission you are running, stall converter etc........
LARRY70GS
239
It's a 1970 Buick Skylark. Probably a 350-2 with the stock gearing, 2.56. Depending on where it was built, he will either have the 12 bolt Chevy rear, or the 8.2 (bastard rear) 10 bolt. Nobody makes gears for the 68-70 Buick Only 8.2 10 bolt except occasionally
Fabcraft, and they only make 3.42 and 3.64. He will also need to change the carrier, another problem.
Vicious2316
Western NC
Totally agree!
