Rear Bulbs
Thread starter #1
chartny
11
Upstate NY
Buick Lucerne '11
Had both turn signal bulbs fail within couple weeks, along with one marker bulb, and the other one was black but still burning. 63K miles '11 Lucerne. Is this normal, or more likely bad bulb supply at GM?
-chart-
159
have you checked your alternator output voltage?
if no issue the bulbs are 7 years old and may start to fail due to age.
AnsonJ
Fishers, IN
2010 Buick Lucerne
I had to replace the turn signal bulb for the left side on my 2010 Lucerne last year... it had about 60k on it.
might just be the bulbs aren't that great
AJ
Thread starter #4
chartny
11
Upstate NY
Buick Lucerne '11
I put my Carchip recorder on it today. Daughter and friend going on a ~50 mile trip each way tonight. It is set to read volts along with other data and I will pull the data out when convenient. So it gives a reading every 5 seconds. If the volts are off, not much that can be done. Regulation is not done in the Alt like old school cars. I would guess it is in the body control module.
-chart-
Thread starter #5
chartny
11
Upstate NY
Buick Lucerne '11
Volts seem to be fine. Carchip recorded about 35 minutes of constant speed at night, rest stop and go.
My error was in not doing all the rear bulbs at one time.
-chart-
