Rear heat duct
WWS
2015 Lacrosse
I'm not getting any air out of the rear passenger area duct.
The louvers are open and the thumb wheel opens and closes the doors (shined a flash light in there)
Put the heater fans up high but still no air flow to the rear.
Is there a hidden knob or switch somewhere?
Or is this a problem for the dealer?
Mad*Max
52
48
Toronto
did you try playing around with the vent settings to control the direction of the air flow on the HVAC control themselves? try with the air conditioning on full and see what happens...to answer your question there is no other knob to turn on.
HMTJ6821
Buick LaCrosse 2016
I believe that only the cooled air exits from the dual ducts on the back of the center console. Heated air usually is ducted on the floor from underneath the two front seats.
WWS
You are right. Ducts are for the A/C.
Today, my elderly back seat passenger appreciated the small blanket I gave her to use.
I'm glad I sit up front.
Thanks.
cheflionfoot
Simply change the direction of the air flow manually to come from the dash board front vents to have heat come out of the rear seat ducts.
