Rear suspension too stiff on 2004 Buick LeSabre
domi_ferr
2004 Buick LeSabre Custom
Yesterday I noticed that all of a sudden the rear suspension on my Buick LeSabre was too stiff and very rough going down the road. I believe that my rear shocks are filled with too much air. What would cause the compressor to all of a sudden fill the shocks up with too much air? What would be the problem here?
725
If it's below freezing the pump air exhaust may be frozen and has no way of leveling. If you can get it in a warm garage or the temperature changes it will melt and start working normally. The pump may have a short, online videos for the repair. The wiring harness has a short. The level control is bad or has a short.
Here's addtional information and the fuses to check.
Buick LeSabre: Which fuse and fuse box do i check auto-leveling…
LARRY70GS
109
Oakland Gardens, N.Y.
98 Riviera, 70 GS455 Stg1
The Factory Service Manual has trouble trees for problems with the ALC. Is the back of the car too high?
