Regal, GN, Power antenna
txbarney
Central Texas
I repair Delco power antenna. The main problem is the broken plastic cord, I replace the plastic with a steel cable with a plastic coating and it should last a long time.
The charge is $75 including return shipping......
If the antenna has a broken or damaged mast, that can be replaced with good used mast.... that is $20 extra.
Send me a PM for more details........I can usually turn them in 2-3 days.
