Regal TourX Keyfob for a Sportback/GS?
Anaduff
480
St. Paul, Minnesota
2019 Insignia GS
Crowbar?
Because tire iron is locked in underfloor storage?
Wait no tire iron from factory...
Nevermind.
I suspect the powered versions can be unlocked both ways--electrically & manually (including a crowbar/oxygen lance/whatever is laying about). But if you push the badge and hear a hum/whirr>click< then I'm not so sure...
L J
525
Regal TourX
Isn't that the sound whats his name heard, when they blew up his Caddy at Tony Romas?
verano4u
16
2019 Sportback
Has anyone else tried the 13508414 keyfob in any trim 2018 and up Regal Sportback model other than Chocomon and got it to unlock the rear hatch?
I have also been looking at the part number for the interior trunk release switch for the Regal Sport back - GM part number 84389158 - It mounts in the driver door in the small storage pocket beside the bottom speaker. Someday I will have to take the driver door panel off to see if the wiring harness in my Sportback Preferred II supports the switch by having a connector there for it.
97
92
1996 Buick Park Avenue 2020 Buick Regal Sportback Essence
I have in my possession a 2018 Lacrosse key, part number 13508414, the one that Chocomon used. I will try to get it programmed to my 2020 Regal Sportback Essence within the next week or two and I will report back.
97
92
So I was unable to program the Lacrosse key fob to my Regal Sportback. It was a spare 2018 Lacrosse key that my dealership had. We attempted both methods of programming, using the door lock cylinder method and through the MDI diagnostic tool. Maybe because it was a key from another vehicle it didn't work. I'm not sure and neither is the technician.
Both styles of latch have an electrical connection, otherwise they wouldn't get the "unlatch" signal from the BCM. So the only thing I can think of is the radio receiver and BCM do not have the programming to accept a signal from a key fob to unlatch the liftback.
Maybe if at some point I feel like trying again, I'll buy a new, never used -8414 Lacrosse remote and try again.
Jack GS
560
93
Metro Detroit
2019 Regal GS
The thing is, I did buy a brand new fob (albeit a TourX fob, not a LaCrosse fob) and it still wouldn't pop the hatch. I'd bet the results would be the same with the LaCrosse fob. The receiver to BCM communication, or lack thereof, makes sense to me.
Did the other buttons function properly or was the whole fob dead?
I wonder what is different about @Chockomon's Essence that allows the fob to work...
verano4u
16
2019 Sportback
Pretty sure the fob is required to be ready for programming. The used fob already has programming in it and the used fob would need to be prepped to be in programming state before the fob is added to the car. Not sure how that is accomplished with used fobs. But a new fob would be the real test.
FavaBean
349
DE
2018 Regal TourX Essence
Just checking (and not to insult your intelligence!) But on the TourX, it requires 2 quick presses of the remote to activate the hatch. A single press and/or long hold DO NOT work.
You did try double pressing, correct?
97
92
I had that thought as well. However, in my mind at least, the fob is just sending a signal, it's the car that needs to learn the fob, not the fob learning the car. But perhaps the key does actually learn the car as well, I do not have a definitive answer.
But as @Jack GS mentioned, why would a Lacrosse key work but not a TourX key? Especially when they have the same FCC frequency.
Unless further experimentation proves otherwise, I truly think because the Sportback doesn't have a power liftgate, GM figured you would have to take one step to open the tailgate either way, whether that be taking out the remote and pushing the button or pressing the badge on the tailgate, so they chose to take the cheap route and just not include FOB functionality for that.
fng
102
Delaware Ohio
Then they saved even more money by eliminating the button that releases the trunk lid from the driver's seat in just about every modern car.
verano4u
16
2019 Sportback
Took a look at the trunk wiring diagrams at the dealer and the Lacrosse does not have a power opening trunk just like the Regal sportback, and showed the wiring to the rear trunk release was the same in both cars. I know the BCM would have to know what to do to open the hatch with the fob.....that may or may not be programmed. I am still going to take my drivers door panel off to see if there is a connector there to put in the remote hatch release. Part number is in my first post above.
Jack GS
560
93
Metro Detroit
2019 Regal GS
No worries! It's good to be thorough and make sure the basics are covered.
And yes, I gave it a double press. When that didn't work, I just spammed the trunk button. I didn't expect that to work either but it made me feel better
Anaduff
480
St. Paul, Minnesota
2019 Insignia GS
You guys...
I've got no interest in getting a remote hatch release to work--but you did make me wonder just what part (latch version--look at post #37) is installed back there. So for what is worth, here is a picture:
1500cc
92
Ontario
2018 Regal GS
I bought a "new, virgin" 13508414 fob from eBay and tried to program it to my 2018 GS. No luck.
I was able to enter programming mode, but when the DIC said it was ready for fob 3, 4, or 5, and I placed the new fob keys-up in the tray, nothing changed.
Maybe I'm doing it wrong? For those that successfully programmed a new fob, the instructions say to remove the cupholder liner, but I don't see where that does anything. I just placed the fob in the skinny plastic tray forward of the actual cupholders (where the fob icon is). And does it take long for the car to recognize the new fob has been placed there?
verano4u
16
2019 Sportback
Make sure you put both current working transmitters(fobs) in the storage bin in step 1.
In step 2 just use any key from the two working fobs.
Did you continue on to steps 4 and 5?
1. Place the recognized RKE
transmitters into the storage
bin with the lock icon.
2. Insert the vehicle key of the
new RKE transmitter into the
key lock cylinder on the outside
of the driver door and turn the
key counterclockwise to the
unlock position five times within
10 seconds.
The DIC displays READY FOR
REMOTE #2, 3, 4 or 5.
3. Place the new RKE transmitter
into the storage bin with the
buttons facing up.
4. Press ENGINE START/STOP.
When the RKE transmitter is
learned, the DIC will show that
it is ready to program the next
transmitter.
5. Remove the RKE transmitter
from the storage bin and
press the fob unlock button.
When all additional RKE
transmitters are programmed,
press and hold ENGINE
START/STOP for 12 seconds
to exit programming mode.
