Rotor & brake squeak
Rik
2006 Lucerne
Anyone ever experienced their replacement rotor and front brakes squeak afterwards (AC Delco Parts)? If so, how did you fix it? Thanks.
728
Define squeak? When applying or driving, both or just a single wheel, V8 or V6, year? Was this something you did or a shop?
If you did the brakes what steps did you do when replaced them, details help others who may have had the same problem.
Rik
2006 Lucerne
When applying... Its a 2006 v6 lucerne-cxl..tge squeak sounds like it's coming from both front wheels but louder on the driver side. It happens in about 80% of my stops.... I had someone else do them...he lubed the contact points and replaced them like normal if that helps.
The new Rotors were cleaned before they went on.
728
A couple of things, as none of us watched it being done. I guess the first one is what has been the response from the person who did it.
Were the hubs cleaned of rust prior to putting on the new disc?
Was the pad and caliper dry fit for proper movement prior to install?
Did the brake calipers get inspected, cleaned along with the guide pins and get relubed or checked?
After installation did new pads and disc get a proper burnish?
Are the calipers properly torqued?
Are the wheels properly torqued?
Not saying that all these items are the problem just some may lead to it as again none of us were there when they were done and this is just basic brake installation steps.
polarzak
16
Many y DIYs and corner mechanics forget to burnish the brakes. If it was not done, it "could" cause a squeak, but that would be more of a concern if only the pads were replaced. Without having to take it all apart and checking that everything was done as in the above post, try bedding them in. It should be done anyway to ensure logevity and better brake performance. Search "brake burnishing" or "bedding in brakes"
Rik
2006 Lucerne
Thanks. Will look into it.
Rik
2006 Lucerne
I believe all the above was done as I watched the installation. Maybe the squeak will eventually stop. I read on another website it could take anywhere from 250 miles to 750miles for squeaking to stop with the new rotors and brake pads, not sure how accurate that is.
728
It's just a point of asking as it's been done in the past where someone just pulls off the old rotors and pads then just tosses on the new parts and gorilla torque the parts and wheels down. Then they wonder why there's problems.
You may want to try burnish them again or if it wasn't done. If you can check the rotors for any possible scratch marks, front and back, in case something is rubbing.
Rik
2006 Lucerne
Okay... I'll try to burnish them again, but there are no scratches on either side of the rotors. Took the wheels off 4 times already to inspect and redid the process to make sure nothing was missed. Brakes squeak the loudest when slowing to a stop or applying brake at high speeds like on highway.
728
There is some squeal stop from CRC but no guarantee that it would work. GM had some pad issue on the 06-07 but have to assume those pads are long gone out of inventory.
The only other item that could, but seeing how no marks are on the back, is the dust shield rubbing. That's about the limit of the common knowledge I have on brake noise. Hopefully they will quite down after some milage.
Rik
2006 Lucerne
Oh okay... Keeping my hopes up. Thanks for your help.
