L.E.V.I
- 0
- 1
- 03 century
I have an 03 century i changed the plugs and wires, and now it is running worse than before. Any ideas on what it could be?
Me too.just today.idles really rough, almost wants to stall.i been checking you tube etc iacv looks like the next thing to check.25-50$ part though...on a possible fix I don't know if I should risk it yet without more informationI have an 03 century i changed the plugs and wires, and now it is running worse than before. Any ideas on what it could be?
I have actually.did the plugs and wires yesterday and it runs significantly better but hardly stayed running at an idle.Make sure you have the spark plug wires going to the correct ignition coil towers. It's very easy to mess up.
No sir I have not.i don't know how at this point, tonight my lights quit working, thinking my multi function switch went out as well, so I will be dealing with that next.its becoming more and more expensiveRingo, have you checked your fuel pressure and operation of the fuel pressure regulator?
Yes but they have been on since I got it.it has been wrecked.multi function switch went out tonight so now no lights.ordered it now just waitingDo you have a check engine light on?
