Herb Miller
- 2
- 3
On 2019 Regal the navigation system is not working and all i get is a message saying the SD Card is not valid. This came about when i was trying to get the map on my phone to display on the Buick screen.
I've had that happen 2 times, both when phone was plugged into car when starting up and Carplay and infotainment booting together maybe had some kind of conflict. Next restart with phone unplugged the built in nav worked fine.On 2019 Regal the navigation system is not working and all i get is a message saying the SD Card is not valid. This came about when i was trying to get the map on my phone to display on the Buick screen.
Not sure lots of clicks here and thereWhat exactly did you do?
So how do I fix itWhat exactly did you do?
If your best guess is lots of clicks, make an appointment with dealer and dont mention the clicks.So how do I fix it
#8473 9527 was the newest available when we got one last October. I haven't kept up with any updates since then, but check that thread for a little more info...So how do I fix it
and your system will reject it.The SD cards are vin binded.
Or just use AndroidAuto/Apple Car play and have free, current maps with more accurate traffic info.If your best guess is lots of clicks, make an appointment with dealer and dont mention the clicks.
Looks like the newest version is GM 86779704, if you need a new one.So how do I fix it
Finally fixed, had to find how to eject the SD card and where it would be ejected. Found by searching on "find Buick SD card slot" then going to "Proper Navigation SD Card Ejection". My car did not have the screen messages discussed. However, after finally locating the SD card, next to the USB port, I found it was ejected by following the press here instructions. Reinserted SD card and all was well, system back to normal.On 2019 Regal the navigation system is not working and all i get is a message saying the SD Card is not valid. This came about when i was trying to get the map on my phone to display on the Buick screen.
The SD card slot always seemed to be in a precarious spot where someone carelessly dumping things in the console storage could easily damage the card, slot or both. It's one of my favorite reasons to get a console storage tray for ~ $20. Ours is very similar to this one.Finally fixed, had to find how to eject the SD card and where it would be ejected. Found by searching on "find Buick SD card slot" then going to "Proper Navigation SD Card Ejection". My car did not have the screen messages discussed. However, after finally locating the SD card, next to the USB port, I found it was ejected by following the press here instructions. Reinserted SD card and all was well, system back to normal.
I put a little piece of electrical tape over mine for this reason.The SD card slot always seemed to be in a precarious spot where someone carelessly dumping things in the console storage could easily damage the card, slot or both. It's one of my favorite reasons to get a console storage tray for ~ $20. Ours is very similar to this one.
erm, nopeLooks like the newest version is GM 86779704, if you need a new one.
- GMPartsDirect.comPart number 86779704 $166.93 is no longer available and has been replaced by part number 85549038 $337.03.
85549038 $337.03 navigation data card is not listed for use with the vehicle per the licensed GM parts catalog.
84530371 $164.38 navigation data card is listed for use with the vehicle per the licensed GM parts catalog.
