Service Battery Charging System
A-Rock
Tulare, CA
2015 Verano
I just reconnected my battery after removing it to replace some parts under the hood. The engine won't start now, and I'm getting a "Service Battery Charging System" message on the instrument cluster screen. When I turn the key to start, I just hear a click and nothing else. No OBDii codes are appearing on my code scanner. IMG_20190608_104208.jpg
The car was running fine and starting no problem before I removed the battery. But now I don't know what to do. The manual says to take it to a dealer to have it serviced, but since it won't start, that's impossible aside from having it towed. I've already tried jump-starting it with another vehicle.
Electronics are working properly (radio, lights, door locks, etc.).
Does anyone know what I can do to get it running again?
2015 Buick Verano 2.4L FWD Automatic
1,427
You did reconnect the cables back to the correct terminals on the battery?
Are you sure the cables are tight?
A-Rock
Tulare, CA
2015 Verano
If the cables are correct and tight, maybe it's time for a new battery if yours is original to the car?
I did tighten the cables down. There was no play in them at all.
I just took the battery to O'Reilly's to have it checked. They said it's at 9 volts so they put it on the charger. I'll be getting a call from them within an hour to let me know if the battery will accept the charge or not.
A-Rock
Tulare, CA
2015 Verano
Yes and yes. It would be very difficult to swap the terminals because of how the battery fits in the compartment, and how intricate the leads are. My battery is on the charger right now. I'll find out soon if it's going to hold a charge.
Full Member Since 2005
8,665
1,096
SE
After recharging (if it will) have the battery load tested. Sometimes when you remove a battery, the sediment in the bottom will be disturbed and cause a grounding of the cells.
A-Rock
Tulare, CA
2015 Verano
If the cells were grounded, is it possible that the sediment would settle and the issue would be resolved over time?
A-Rock
Tulare, CA
2015 Verano
Just got the battery back. It charged and tested good. I re-installed it and the same thing is happening. I guess my only hope is to have it towed to the dealership for service.
8,665
1,096
SE
Did they do a LOAD TEST on the battery? The voltage may look good after a charge, but the load test may fail! You need to have a 500-amp carbon-pile load tester hooked up for 15-sec to see the condition of the battery.
KevinJ
Contributing Member
337
69
Ohio
Ditto the Load Test by the previous poster.
If the battery only had 9-volts when you took it in for testing, then that would make it a prime culprit for your problem. Not sure about the sediment thing and but if it's the original battery then there is a good chance you probably need a new battery. A good battery that is actually disconnected should still hold a charge of over 12 volts for several weeks if not months. New batteries can sit on a shelf for many many months and will still have a 12V+ charge.
Lastly, and I'm not trying to be critical, but are sure you actually hooked all the leads up correctly when re-installing the battery, especially the positive side terminal. And I do know you probably didn't get the positive and negative reversed as that would be hard to do with this vehicle. I recently changed the battery in my 2013 and was surprised at how "involved" it was. I actually took pictures of the all the cables and leads as I disconnected it to make sure I got them back in the correct positions. Also, my car actually sat without a battery in it for 3 or 4 days before I was able to get the new one purchased and installed. And it had no problems in starting right up.
Good Luck and let us know the outcome.
Lisa LP429
2013 Verano
I'd like to know too. I'm getting the same warning message and am going to get my battery tested tomorrow.
G-703127
Recently purchased a 2013 lacrosse and having the same issue, had the car on and disconnected the positive cable from the battery so it’s not the alternator. Have no clue what the issue is stemming from
thunderkitten
2014 Buick Verano
Any luck with all this? My car is now doing the same. 2014 Buick Verano. Just replaced battery, alternator, and starter. All electronics work, car only makes the click noise when attempting to start.
1,427
Did you test any of those parts before changing them?
Did you test the starter relay and check for blown fuses?
Ksuarez23
Verano
I’m having the same problem. Did you ever resolve this problem?????
MrAllen86
Buick Regal 2011 2.4 cxl
I'm having the same problem with his car and then changed out every part necessary to change out all lights Electronics seem to be working same thing is on in my Buick 2011 Regal 2.4 L cxl I'm paying a car note on a car that had no check engine light but nothing on but this came on all of a sudden and I'm stuck with it Buick this cannot be happening I need some help and I need some help now I'm going through enough to win this time car went out a week before my wedding leaving me with no transportation paying for Unnecessary parts and still a car note
Chinkb
2011 regal Buick cxl
I just reconnected my battery after removing it to replace some parts under the hood. The engine won't start now, and I'm getting a "Service Battery Charging System" message on the instrument cluster screen. When I turn the key to start, I just hear a click and nothing else. No OBDii codes are appearing on my code scanner. View attachment 16206
I’m having this same problem now did you find out what it was ??? I’ve had my alternator battery an starter changed started with a new battery first three days later it wouldn’t start sooo i trued the starter an alternator
1,427
Did you do any testing of those parts before replacing them?
Did you test for a parasitic drain?
