service engine light after changing headlight assembly
Salvaing
Interested if you find out where this $%@#& aftermarket wiring harness is not correctly wired ;)
Maybe the easier way is to compare aftermaket harness with genuine one wire by wire ...
Unfortunately I sold the original headlight housing.
2003 Rendezvous Owner
Can someone post the headlight circuit as the one in my manual is not readable. Specifically, I am looking for the connectors with wire colors.
Thanks,
Salvaing
I'm not sure the aftermarket headlight circuit is different than original.
I wonder if this is not a problem of wires and connectors quality of this "made in China" product.
I read (I dont remember where) that the wiring impedance is very sensitive for DRL management.
Going back to original headlights doesnt fix it ?
Salvaing
I bought an used Buick Rendezvous Headlight Bulb Wiring Harness OEM (both L&R) on Ebay.
I will swap with aftermarket wiring harness this week-end.
Wait and see ...
Salvaing
Hi guys.
I swapped the $%*@&£µ aftermarket chinese headlight bulb wiring harness with the used OEM wiring bought on Ebay ... and IT WORKS !!! :headbang:
DRL management came back (Hi beam at reduced voltage) with a regular Low / Hi beam (y)
No error code.
Beware : left wiring is different than right !
Before : all light always ON
After : only DRL (Hi beam at reduced voltage)
richardnewton
139
31
We replaced OEM foggy headlights with an identical clear pair we found in a junkyard @$40/each. We kept all original bulbs and electrics so no issues.
