Sputtering and brakes not working at the same time.
Lefty#53
2003 Buick Lesabre
I went to pick up my Great Granddaughter from school and all was well. Went to start the car and I had to use throttle to get it to start. Once started, it started sputtering and then a high rev of the engine. Went to pull out backwards, and I had to really push hard to get the brakes to stop it. Drove it home and only sputtered when I came to stops and ran fine once on the road. Both feet on the brakes to slow enough to make a left-hand turn after going 55. Just so you know, I have been having trouble starting the car and sometimes have to apply throttle and others it just starts fine. Today was the only day it started sputtering and the brake deal. Any ideas and help is greatly appreciated.
Lefty#53
2003 Buick Lesabre
Forgot to mention, code P0131
Homer Jay
306
New York
2001 LeSabre
Due to the engine close to stalling, there was probably loss of vacuum to the power brake booster.
Not knowing the vehicle history or your mechanical ability it may be best to bring the car to a trusted mechanic.
Lefty#53
2003 Buick Lesabre
Well this car has 89,000 miles on it which is the reason I bought it. But Yeah, this is something I can not work on myself. I have a bad back which had 2 surgeries and just had x-rays, and it looks like another one on the way. I did read about brake booster air leak, so that is most likely the culprit. I hear a lot of hissing in the air intake box before the air filter.
Mad_Coachman
Active Member
1,830
671
Long Island
2002 LeSabre Limited
Sounds like you have a large vacuum leak at the booster or at the other end of that hose to the intake. Check the big fat hose that runs from the engine side of your brake booster to the intake. There is a one way valve at the brake booster that also could be bad but that is unlikely the issue. If the hissing is coming from under the dash it could be a bad diaphragm in the booster which would require replacement of the entire brake booster. If the hissing is from under the hood then it's the first scenario that I described.
Lefty#53
2003 Buick Lesabre
Thank you, I will give it a look.
Lefty#53
2003 Buick Lesabre
OK, I looked at the main hose from the brake booster to the intake. It is fine but, there is a smaller hose that attaches to the intake side off a semi T shape and that hose is missing completely. In other words, it and the Brake boost hose both hook to the intake side off one semi T. I found a picture that looks like it might be the T. As you can see, another smaller hose hooks to it also. That hose is missing, and I have no clue to where it connects to on another end.
Lefty#53
2003 Buick Lesabre
One more thing, is that the Crank Case vacuum line, and where does it hook on the other side?
3,438
You need to possibly get a picture of your vehicle, but it may need just a cap on the open small tube. You can try and plug it to see if it resolved the problem.
Lefty#53
2003 Buick Lesabre
I have looked all over the place trying to find the other end. Even tried a mirror and still do love. I will see if I can cap it and see what happens.
Thunderhawk09
133
2005 Buick LeSabre Custom
first off unless you removed the hose for pic that hose is not fine the booster hose is disconnected from the intake in that picture. that would cause your issue unmetered air entering intake and no vacuum to booster.
Lefty#53
2003 Buick Lesabre
No, that is a picture I found on the internet. The small hose nipple is missing a hose or cap. I tried to cap it and that didn't work. Still sputters.
Mad_Coachman
Active Member
1,830
671
Long Island
I just went out and looked at my LeSabre. That missing hose on yours goes to the Air injection system. Does your car have California emissions like mine?
Lefty#53
2003 Buick Lesabre
I don't know if it does or not. Where does it connect to on the other end? Not sure where to look.
