Suddenly navigation in down, SD card not read.
mike69440
673
2018 TourX Essence
Navigation was working on my way to work. Started TourX after work, No navigation. It could not Load the SD Card. I fiddled with it to make sure it was inserted. What does the little white switch do on the side of the SD card.?
I tried both positions, nada.
Anyone else have the navigation head south?
I called dealer and asked if they could mail a new card to try.
Answer, No we will not do that, make an appointment.
Remainder of infotainment, etc. seems to work . Not tried Android Auto.
A few days ago, it lost all radio presets?
Car may have tens of thousands more computer power than the Apollo moon missions, but as far as reliability goes, not so sure.
Hunter Mike
256
America’s Dairyland
The switch locks and unlocks the card for writing data only. It works for read either way. iirc, once the card is coded to the car it can’t be switched to another.
Did you try another power cycle? Last week I started the car and the screen was blank. It took a good two minutes and two key cycles to wake up. Been fine since.
Infotainment is the Achilles heel of the car. I’m making an appointment soon for the sound cutting out to check for any updates.
mike69440
673
2018 TourX Essence
So magically the Navigation is working again??
So on another subjects related to infotainment, depending on the day.
I lose Android auto.
Radio has lost all the presets twice.
Radio on when I shut car off, sometimes I get back in at end of day the radio is off?
The infotainment system appears haunted.
Ctrcbob
383
Regal Tour-X
OK. First off.
1. Sometimes my audio also goes off when I restart car. Always comes back on when I touch audio icon on screen. This is a non-problem to me. Just touch audio icon and radio comes back on.
2. Radio loosing presets. With me, I would lose only my AM & FM presets. Would NOT lose XM presets. Don’t know if you noticed, but the AM/FM preset frequencies are still in the screen but VERY FAINT. You can still reprogram a station by manually finding that station then touching and holding any of the dark buttons with the very faint frequencies showing. (Yes. It’s a PITA). Last March, dealer flashed the audio system. Corrected problem for a while but then problem started again. After I would reprogram, it would last for anywhere from three days to three months. One week ago yesterday, October 1st, took it to Dealer and got it re-flashed (reprogrammed) again. Technician told me Buick has an updated fix which he installed, however an additional updated fix will be issued in the future. My advice to you is to do what I did before the re-flash. I wrote down the stations (frequencies) I want to reprogram so I don’t have to remember what I want.
mike69440
673
2018 TourX Essence
OK. First off.
I'm relieved to here I am no more insane than before I got the TourX. I gave up the XM radio. In any case it is a good idea to write down the station numbers. Thanks for the tips.
All infotaiment sucks, we should just entertain ourselves driving.
saab93driver
249
2019 TourX
I have had it act up twice in 9K miles. Once the message was the SD card was not inserted, which is was. Restart fixed that, so far it hasn't done it again.
Second the screen basically became unusable, I could change screens but audio was dead (XM, FM, AM - all of it), GPS showed map but didn't move, climate system could only be controlled by hard buttons and knobs, screen showed the climate system but wouldn't update, 4G connection was dead. It all came back to life as normal after shutting off and restarting it (after car sat for a while).
mike69440
673
2018 TourX Essence
I hope GM software guys are not going to get a job at Boeing!:unsure:
Ctrcbob
383
Regal Tour-X
Hey, it’s not only our cars. I’ve had other brands that did the efact thing. Also read about this on other brand forums.
Caltexan
Tourx
I had my infotainment system replaced. Still the same glitches. Navigation blacks out. Back up lines fade. Numbers gray out. Very disappointing. It’s a 2019 tour X.
D2R
491
Michigan
2019 Regal TourX Essence
x10003q
37
2019 GS
Three days ago I had a 15 minute drive to a meeting where the infotainment was working. I have not had any issues with the infotainment screen. When I got back in the GS 2 hours later, the screen was blank. I did have music, but no control over the volume or the station. At the first stop light I turned the car off and opened the door. When I restarted the car the screen remained blank and there was no sound from the radio. When I got home I let the car sit for 15 minutes and then restarted it. The system started and remains working.
Ctrcbob
383
Regal Tour-X
Sounds exactly like the 2009 Genesis I owned. Had to stop for five or ten minutes, like when going to a gas station. Got back in cat and everything worked.
My Tour-X has the problem whereas once in a while (once a month) the Maps does not load. Normally does not bother me as I know where I’m going around town, but if I absolutely need it, I shit cat off, get out, walk around car, get back in and start car. Maps then loads per normal.
Jack GS
608
93
Metro Detroit
2019 Regal GS
I run into this occasionally and a quick "fix" is to go into the Running Applications and Force Stop the Navigation app. After that, it'll boot up just fine and doesn't require a key cycle or waiting period.
