Detigers42
- 0
- 1
- 2015 Verano leather group
I'll do my best to explain my issue. My 2015 Verano temperature gauge had been sporadic for several months. The needle normally is at the midway mark but then it starts to fluctuate between the midway mark and the extreme end to the left of center (what would be the engine temperature when the car is just started) Ultimately what happens is that I get an error message saying the the AC is turning off in order to not overheat. When I called to make an appointment I was told to check the antifreeze. The only place I can see to check the antifreeze is the reservoir which is fine. I can't see how I can access the radiator to check the antifreeze. Any suggestions? Sorry for my lack of knowledge in my description.
