Torque upper intake specs information (lacrosse cxl 2010)
Shahar
buick lacrosse CXL 3.0 2010
Hi
what is the torqe specs for the upper intake and for the spark plugs?
thank's
Rich B.
50
Minot, ME
Shahar
Hi :)
It is strange that there is no general information especially about torque info for DIY'S
Anyway thank you very much, appreciate it
rider47
6
18 N-m (13 lb. ft) for new spark plugs according to Chilton (See the attached Guide). Pauls fixit guide says you go by the feel of the spark plug.
Note: Change the .txt extension to .doc in order to open the file correctly
Rich B.
50
Minot, ME
Forgot, always use a bit of Never-Sieze on plug threads (but who really ever does). Ford back in the past decade was notorious for snapping off plugs or stripping threads (dissimilar metals).image.jpeg
Zeroboostbuick
244
S.W. Ontario Canada
I use Anti-Seize on plugs among many other fasteners.
I mostly like using the Lawson Anti-Seize Stick.
Spark plugs I prefer installing by feel.
New plugs usually need a little more than old plugs because of the crush washer.
If I had to guess how much force I use I'd say 15 ft-lbs with new plugs and 10 ft-lbs on old plugs.
BIG ROCCO
17
PHOENIX, AZ
2012 LaCrosse eAssist P1 w/H-K & Nav
Yeah, antiseize, and I use a short or stubby ratchet when installing to help prevent overtightening (normal or long length OK for removal, if space permits). I haven't had a car with an engine that had spark plugs with a crush washer since the 1960s - are they really still being used? Anything I have worked on in decades uses a tapered seat - I usually put a tiny amount of antiseize on my finger and lightly apply some to the spark plug seat
