TourX lift Kit
Transporter2112
2018 TourX
My wife and I just bought a new from the lot 2018 TourX. Absolutely love the car and got a heck of a deal. The only concern is the ride height. We do spend quite a bit of time on. Dirt roads and had the Buick not been such a great car for the money would have ended up buying a Jeep Cherokee or other SUV. I know there are several options to lift a strut equipped car but haven’t really dug under the car yet to see how the suspension is all put together. Has anybody looked into some 2” or so spacers for the TourX? If not that specifically does anybody have any first hand knowledge on how the suspension is put together and might can offer recommendations?
PrincipalDan
824
Gallup, NM
2018 Regal TourX
Most of us here are trying to figure out how to drop the sucker an inch or so... 🤷‍♂️
Transporter2112
2018 TourX
Well the two aren’t necessarily mutually exclusive. If it’s struts in the front then it should be pretty easy to find spacers for me or lowering struts for you guys if we knew the mounting pattern. I don’t know if they’re universal or not... same for the rear springs.. if we knew length and diameter we could find spacers or drop springs from another application.
GermyShoe
170
Richardson, TX
Regal TourX
I think the A6 wagon has air ride so that it can raise like 3-4 inches from stock, or lower an inch or so from stock. I wouldn't mind having something like that.
Transporter2112
2018 TourX
Yeah. That would be super cool but at what cost. I’m looking for a spacer type kit good for hopefully 2 inches
Idano
157
Preferred Red Needle TourX
This discussion brings up the question,
What would it take to swap in the MagneRide suspension system off one of the TourX Epsilon platform brethren ? Not only for a better ride and handling but would it be possible to use it as a lowering/lifting system for your particular needs or wants ?
PrincipalDan
824
Gallup, NM
2018 Regal TourX
Malibu has a dealer installed lowering kit (roughly a 1/2 in IIRC) I've sometimes wondered if that would fit any of the Regal models.
Magnaride does't raise or lower the car, it adjusts the "stiffness" of the shocks. Being able to float along or get stiff and ride the skidpad.
GermyShoe
170
Richardson, TX
Regal TourX
I feel like the rear geometry is different for FWD vs AWD. Not sure if that matters.
PrincipalDan
824
Gallup, NM
2018 Regal TourX
Depends. I'm fairly certain the Malibu kit is literally just springs.
Although some listings claim 2.0T only. Which makes no sense, not like there's a different suspension design between the two.
Idano
157
The stuff I've read about the MagneRide system is that it isn't just a dampening system but can be set up as proactive to the road surface and thus lift and lower as it drives.
justiz00
85
Tourx
Without more research, I wonder if it is possible to install XT4 struts/springs on the Tourx since it is the same platform.
ezpotato
98
Regal TourX
Custom airlift kit from any authorized airlift (or other branded air suspension) dealer maybe? Otherwise take it to a 4x4 off-road shop and see what they say.
Wlepse
616
NNJ
2018 Regal TourX Essence
I don't know that I would want to lift mine but I would like stiffer springs. Unfortunately those come with a 25-30mm drop. So I was looking into spacers for the top of the front struts which I would likely have to fab myself and a set of threaded coil spring adjusters for the rear. Just haven't had anytime to take things apart to measure.
mike69440
730
2018 TourX Essence
I wrote and called, no one interested.
SmallTownJerseyBoy
It's possible. There's a dealer in Atlanta with a lifted TourX. Not sure who makes the kit, haven't been in touch. But they have it as a $3500 option
