Towing package questions
Mrhdflst
Enclave
I have a 2012 enclave and does NOT have the trailer tow package. From what I can see is the difference is the actual tow hitch, wiring harness and heavier duty radiator. My question is can I replace the stock radiator with the heavier duty one without making other major changes?
redvett
3.8L S/C Member
175
2017 Buick Enclave
You will need the HD trans cooler, wiring for Tow/haul switch and larger radiator along with the hitch and wiring. to be able to tow over 2000 lbs.
