transmission Dextron fluid Type
lasabre
My 2003 owners manual recommends Dextron VIII, Its not made any more everything is Dextron VI , so when I went to the dealer he gives me 10-9118 88864060, its conventional type , the parts guy says you dont need synthetic fluid and they dont use it in newer Buick's only in special transmissions marked HD1, so now when I go on Amazon or E bay to see what they have in Dextron , there are about 5 different part numbers that all say they can be used in my transmission, so which one would you use?
CorvairGeek
3.8L Member
240
58
The Gem State
1996, 92 Buick Century
Any of the first 3 all appear to be Dexron VI, which is now the approved fluid.
You advice from the dealer sounds like the typical, ignorant advice that is outdated or they think they know more than General Motor's engineering.
lasabre
yes you R right they all say anything to sell you something even if its not the right formula, it is not thier car to keep running smooth.
Ameri
78
7
Chicago
2004 Buick LeSabre
I used ACDelco 10-9395 Dexron VI with no problems. And then used valvoline Max life for the next change and I liked it too.
755
From the web:
GM Dexron-VI(J) licensed products have a license number on the container that begins with the letter J. Example: J-60301. This was the first GM ATF to advertise 100,000 miles (160,000 km) between changes for "Normal Driving" conditions and 50,000 miles (80,000 km) for "Severe Service".[24] This fluid is backward compatible with Dexron-III(H) and Dexron-III(G) fluids only.
More info if needed:
DEXRON - Wikipedia
lasabre
From the web:
DEXRON - Wikipedia
Thanks for the research
Zeroboostbuick
347
S.W. Ontario Canada
Dexron III or dexron VI is what you want.
Dexron VI is the replacement for Dex III and will work better.
#1 is AMSOIL
#2 is Mobil 1
AC-Delco Dexron VI is good stuff too. But I would add some Lucas Transmission Fix in with the new ATF. Lucas trans fix is good for older transmissions.
Lubener
24
N.Ohio
"WAS" 97 Lesabre
ANY Dexron 6 will be fine. It is a licensed product annd the only difference is brand and price. Don't be fooled that you should get OEM fluid, it is no better than the others or add any additives..The important thing is you are doing a pan drop (hopefully) and changing the filter.I have used Supertech from WM because the price is best.
Check online, there are a couple of TSB's for your 4T65E transmission regarding upgrading the pan magnet and adding a clamp (Sonnax) to secure the diff. tubes which have a tendency to work loose.
lasabre
thanks for the heads up on the service TSB
Ameri
78
7
Chicago
2004 Buick LeSabre
Thank you for that Lubner! I did those upgrades last year 😎
Ameri
78
7
Chicago
2004 Buick LeSabre
I beginning to believe that it wont matter if I should use a fully synthetic,blend, or conventional with Dextron VI by adding it or changing it .
I agree. Honestly, I’d rather change conventional every 60k or so, than change a synthetic every 100k. After all, you always want fresh fluid. But some might disagree.
LARRY70GS
Oakland Gardens, N.Y.
98 Riviera, 70 GS455 Stg1
I have used Dexron 6 for the last 2 oil changes in my 98 Riviera. The car has the original transmission at 192K. I change it every 20,000 miles and have done so since I bought the car with 86,000 miles in 2004. It shifts mint.
BTW, I use Dexron 6 in the THM 400 in my 1970 GS455. All Dexron is backwards compatible.
