Tried everything..... almost
Thomas mandley
LeSabre
2005 AC compressor working with adequate charge to system but not moving refrigerant. Same pressure on high and low side.
Alan 55
70
Florida
100 to 125 PSI
This is kind of basic but have you verified that the compressor clutch is engaging properly and staying engaged? If the compressor clutch is engaging properly and the pressures remain the same on both sides, it seems that the compressor is faulty.
97PA
13
1997 Park Avenue
Assuming the clutch is engaging, I would look a missing or damaged orifice tube. Your compressor is working (maybe partially), as it's getting to 125psi but it needs a restriction (orifice tube or TXV) to develop a pressure drop for the low side.
