Trifecta Tune
bambam18
20
2014 regal turbo 2.0L
I need a tune repository for a 2014 regal turbo. I have hp tuners dont know how to use it. Can someone please send me something. Thanks
14RegalGSAWD
Madison, WI
2014 Regal GS AWD
I'm running Trifecta in mine and very happy. There is always a little lag with a turbo to spool up, but you can DEFINIETLY feel the added torque and boost.
FWIW, I also ran a tuned VW Passat 1.8Turbo for many years....it also had the turbo lag issue, but mine was a manual so that was easy to overcome. It's just the nature of the beast with turbos....they don't generate much boost until the RPMs are spooled up. Pair that with an automatic transmission....it's a little lag off the start, unless you pre-load the engine.
BoostedRegal2.0
219
I have the Trifecta tune and it definitely woke my car up, plus it shifts so much better. I always use 93 octane fuel and I haven't had any issues at all with the tune.
Off the line there's a little lag until the turbo spools up, but that's normal for a turbocharged car. When I'm cruising along and accelerate there's no lag at all. I put the hammer down and it takes off like a rocket.
I recently replaced the spark plugs and air filter since it reached 50K miles, and it does run a little better now.
mlarabia
6
Northern NJ
'17 Buick Regal GS
I have a question regarding the Trifecta Tuner. Their site says that their new hand helds will NOT register on the computer when you flash the tune. Is this accurate? I have been holding off getting a tune because my '17 GS has 23k on it so I have alot of warranty time left. I love the car but the lack of power is the one disappointing feature on the car.
BoostedRegal2.0
219
I haven't heard of anyone that got denied warranty work with a tune. You can always flash it back to stock before you take it in for repairs to be sure.
mlarabia
6
Northern NJ
'17 Buick Regal GS
Neither have I but I was told that the ECM records the number of times it has been flashed and if Buick doesn't have in their database that they flashed it then they will know I messed with it and potentially they may not honor my warranty. I'm probably just being paranoid...
pigsnzen
54
12
BFE, KY
'12 GS 6MT
There's been several people on this board as well as the Facebook group who've been denied coverage due to a tune. The dealer might not have the equipment/experience to detect a re-flash back to stock, but if/when they ship it off to GM's engineers it can be found easily. Tunes can really wake up our engines, but Caveat Emptor...
luke1333
A Regular
correct ecm records number of times that it has been flashed and can tell if it was modified as well. probably wont matter unless you need an engine and the dealer will need proof showing no tune for warranty
BoostedRegal2.0
219
Trifecta claims loading a performance tune doesn't change the flash counter. And if you load the stock tune back before you bring it in they can't find what isn't there.........
pkgmsu2000
Contributing Member
173
Denver, CO
2014 Buick Regal GS
the GS stock from factory brings more than enough power to the table. if you are disappointed then you must not have spent the proper time on a test drive. be thankful that you have a couple of proven tuner options available. there are truly plenty of cars on the road that would really benefit from a tune, but none are available due to lack of demand.
Justplainlow
2012 regal gs
How does the trifecta tune affect mileage? I have a 2012 gs automatic. I’m already very let down by the mileage for. 2.0 although I otherwise love the car. Will this tune change mileage at all? This seems like the best tune on paper, is it?
papoman3
2016 Regal GS
Key word "Claims"
@mlarabia Can you please let me know if you find some info on this? I don't want to void the warranty on mine either. Thanks
mavv
Northern Michigan
2014 Buick Regal Turbo
I have a 2014 regal turbo and I’m getting 22 average- that being said I love the feeling of this tune and driving confidence In this car with this tune is through the roof. I noticed that bad gas or less than 91 the car really hates it. Non ethanol premium if you can find it is amazing and better mileage out of it but you’ll come in pretty even because of the price. Bottom line not a huge change in mileage. Keep it out of boost on the highway it’s usually low 30s. Do it you won’t be disappointed.
