Unibody/Sheet metal punctures - how to seal/patch
BuickGirlFromMars
442
Soooo, if you have a puncture in your sheet metal(like a floor or a spare tire well), how do you fix that? I could bend it back, sand the surface, hit with some good primer and paint or other sealer, but then how do i.. make it not a hole? I know the patches in the trunk and other spots for factory stuff, but i dont know what those are or how to do it.
1,016
SE
Flex Seal may work better than silicone in that situation. ;)
BuickGirlFromMars
442
i would seriously take that as advice but given its a meme and a snake oil product i am not sure i can
1,016
SE
No snake oil in that product!
2,936
I guess it would depend on how much you want and can do. Cutting out the bad rusted metal and welding in good metal would be the proper and most involved. Spraying the rusted area with a good converter both sides, sheet aluminum on oversized hole, fiberglass over and rubberized undercoating on both sides. It's the difference between fixed and fully repaired properly is up to the owner.
JoeBlog
Buick Owner
245
215
Wichita
If it was an older car, I’d use POR-15 sealer on it. A newer car, I’d get out the MIG welder and a patch panel. A classic car, I’d fabricate a new section of metal, weld it in and seam seal it. And I’ve done all of those.
BuickGirlFromMars
442
its not rusted, its literally like if you took a screwdriver and poked through your pop can. it must be recent.
2,936
Had the problem on the 95 Lesabre, didn't care about the appearance so did the fiberglass repair and years later it's still holding.
Anaduff
Associate Member
667
93
St. Paul, Minnesota
2019 Insignia GS, 2003 Jaguar X-Type
Depending on how accessible both sides of the hole are & what might be laying against on side (carpet or the like), a screw or bolt (depending on the size of the hole), a couple of washers & a hex nut should make short work of it. Stainless steel hardware would probably last longer than the car & some rtv silicone between the washers & the sheet metal will make it water-tight.
Drakito
179
Southern Utah
2003 Park Avenue Ultra
I usually just weld a patch panel in. Unless it's a classic car, then I will get complete replacement floor pans, or fabricate and bead roll some myself. I have done the stainless bolt through trick with silicone if the hole is small enough, but usually if it is that small a MIG or TIG can fill it in short order, then grind it flat and hit it with some paint for corrosion resistance.
