Water Leak in Passenger Footwell
FingerLakesEncore
I've got some water leaking into the passenger footwell in my '13 Encore.
I assume it's a clogged drain pipe for the AC condensor. Can anyone suggest otherwise or how to clear the clog before I need to take it to the dealer?
Cheers
292
you have to clear it from under the car using a length of wire like from a coat hanger and any shop should be able to do it. You are sure it's water, no engine coolant smell?
Zeroboostbuick
344
S.W. Ontario Canada
Years ago on a passed carI had water leaking into the passenger footwell.... and it came through the cabin air filter area. The cabin air filter cover somehow shifted allowing water in.
adamcar
9
Check your sunroof drains for clogging, cracking, or disconnected from grommet. Huge problem on the SRX, hope not an issue with Encore. Water issues are difficult to find if not obvious. Hope it is the a/c drain like you think.
