Water on Driver Side Floor
Marc0557
Cascada
Has anyone experienced water on the driver side floor? My Cascada is Garage kept. Rarely driven in the rain. However, on hot humid days with the A/C on; I get a slight amount of water dripping from under the dash onto the driver side floor. Near the gas pedal. I do see a lot of A/C water on the pavement.
1,402
Thank You. Any idea how/where to located it?
Look under the car for the drain which should be obvious with the AC running.
Vector
2016 Cascada
It is almost certainly a blocked drain due to a flap at the bottom, that is stuck/clogged which will cause it to back up into the footwell of either side. I had the same problem until I dislodged the gunk, and I took off the flap so it would not happen again. I did the same thing to the other side as a preventative measure, even though it was not clogged.
