Weird starting issue on 2002 Buick Regal
ohmybuick
Hey everyone. I just bought a 2002 Buick Regal LS off an auction (great deal BTW) that starts fine the first time around, but after I drive it for a bit, turn it off, and come back out the Regal doesn't want to start. I have to wait about 15 minutes before it fires up again. I did changed the MAF sensor but am still experiencing this problem.
278
1. Do you have a check engine light on?
2. Have you done a fuel pressure test, both when cold and when warm, with engine running and after engine is shut off with a few minute wait?
txbarney
Central Texas
Coil packs are a place to look. A common symptom is "goo" coming out to the base of the coil pack...this is the potting compound on the circuit board overheating and flowing out.
artiv1976
Almost 100% positive it is your fuel pump. Had the same issue last year and after replacing just about everything else fuel and air related it ended up being the pump.
