What is this noise 3.8 lucerne???
stocker340
97 park avenue
noise video
I have a 3.8 lucerne 160000 miles with the above noise
I have taken the serpentine off and run the motor with the same noise!
I have pulled each plug wire off hoping it wasnt a bearing or something!
I changed the oil again 5w30 synthetic like always with filter and run almost a quart of lucas engine oil stabilizer with it and drove 300 miles afterward and it still does it.
The noise started a month ago
Car runs great just the noise? It seems to have everyone stumped.
Any Ideas buick folks?
Click noise video link at the top
Thxs
Dale in south dakota
287
Chirping belt??
Zeroboostbuick
309
S.W. Ontario Canada
Since the noise is still there with out the accessory belt, I wonder if it's the harmonic balance crank damper or something caught in behind it.
724
While it may be something else, little hard to hear location from video, this may be a possibility as mentioned above Zeroboostbuick in the beginning stages. The video is really bad harmonic balancer noise but you may want to check yours.
stocker340
97 park avenue
i think its a bit louder in the passenger side area?
Zeroboostbuick
309
S.W. Ontario Canada
Take the positive crankcase valve out and see if that's the problem.
Takes a few seconds to take the valve out. Just foogle " 3800 PCV replacement" if you don't know how. Sometimes you might need needle nose pliers if it's very dirty and tight. Even if the problem is not the PCV valve, you can use any type of cleaner to rince it out like carb cleaner, brake fluid etc and give it a cleaning.
stocker340
97 park avenue
Thanks for your reply as I made a mistake here
I should not have said fixed as it isn't fixed yet as I had a post in another area on this site about my Buick park Avenue that was solved
I am going to try this and see what happens and thanks for your input
stocker340
97 park avenue
I am going to try this I will reply back
century61
Indiana
2008 Buick Lucerne 3.8 liter
noise video
Thxs
Im late to replying to this thread but the problem is still there so here is my input.
This sound is probably a bearing issue. Here is how I diagnose these things -->
Get a one gallon jug like what window washer fluid comes in. Cut off the bottom about an inch up. Then take a large screw driver and run it thru the bottom you cut off so that the handle of the screw driver is stuck in the top opening of the jug. Now you have a speaker :) Take it and stick the end of the screw driver on one of the pulley's or near it and listen. When you find the pulley where the noise is the loudest then you have found the bad pulley.
Remove your serpentine belt and check the pulley for movement. It shouldnt move back and fourth. It should just rotate smoothly.
Replace the bad pulley.
Zeroboostbuick
309
S.W. Ontario Canada
