Wheel Swap - '15 Regal T / '05 LaCrosse CX
dnoel01
New Hampshire
2015 Regal Turbo Premium FWD, 2015 Encore Premium AWD, 2005 LaCrosse CX
I'm planning to install new wheels and tires on my 2015 Regal T and was wondering if the factory 18" 7-spoke chrome alloys I'm removing could be installed on my '05 LaCrosse CX. Is the offset compatible?
189
The Regal is a 5x120 bolt pattern, the LaCrosse is a 5x115 bolt pattern. You would need to use adaptors.
dnoel01
New Hampshire
MelsRegal thank you for your response and I apologize for the delay in responding back. So if I change over to a 5 on 120 hub I should be good? Not sure I'll go through with it as it will most likely be cheaper to just buy aftermarket wheels.
Zeroboostbuick
244
S.W. Ontario Canada
Mel said...
Your's is 5x120 and the 2005 LaCrosse is 5x115. You need an adapter.
Kinda like this.
Some big tire shops have them. Or order online form wherever. Just remember your and other people's lives depend on them. So choose wisely.
And look for the thinnest, like 20 mm thick, so your tires/rims don't stick out.
