Where is the fuel pump relay fuse? Or if anyone has any other advice on this issue...
mcafc98
1994 Buick Roadmaster
A year or so ago, my fuel pump went out. A mechanic I brought it to fixed it very cheaply, the issue was a grounding issue causing a fuse to blow repeatedly.
The problem has come buck, but I am having trouble finding the blown fuse. The fuel pump fuse in the fuse box is fine, so I want to check the "in line" fuse, but I can not find it. I have seen a diagram for it here: https://www.justanswer.com/uploads/goodwrench9124/2008-07-30_205126_buick_fuel_fuse.gif
but I just can not find the darn thing. Here is an actual image of the area I am looking in:
Also, I have an image of the wiring harness the mechanic replaced which was attached to the driver's side door last time(this was the grounding issue) if anyone knows anything about this?
Dirtybob
95 RMS
Lift the lid on the black box in bottom left of your first pic.
Fuse at position "2", relay at position "A"
