Why is My TourX slow?
Wag0n
40
2018 Regal TourX Essence | 2019 Envision Essence
8.4 second 0-60 with non ethanol 91 premium on every tank, going down an on ramp, in 40 degree weather.
30000 miles of being a good reliable car. Owned since new. No engine codes, always serviced, and good highway mileage.
Just doesn't feel like 250 hp / 295 tq. After 40 mph it feels like it hits a wall and even though it's floored, there's just nothing there.
Good car, just no power.
Any ideas?
adam728
118
Seems very odd. While 0-60 in the 6 second range is doable, it takes a certian technique to achive. But just flooring it from a stop should still net you probably 7.0-7.4 sec 0-60. What's most telling is that 40-60 is over 4 seconds. Seems like it is reeling back boost, timing, or throttle. If memory serves me that should be maybe 2.0-2.5 sec for our cars.
Have a way to record OBD2 data during a run?
jdoodle
132
66
Texas
2018 regal tourx
Isn't 93 recommended? The systems could be retarding timing a bit.
Wag0n
40
Did another test, this time accelerating but only pressing the pedal up to the detent, and not past it. I've always felt that partial throttle acceleration felt stronger.
With an extra person in the car, at partial throttle, and on a flat surface, I got a better time at 8 seconds flat.
I read a comment about octane and 93 shows no difference to 91 from my past tests. I don't think that is the issue.
Is the pedal hardware perhaps not sending the right signal? I have a scan tool with the capability of recording data - what data should I be looking for? Or perhaps try a pedal replacement?
Wlepse
747
NNJ
Am I mixed up or was there not an extended warranty on the accelerator pedal? I thought it caused limp mode but maybe this is another failure mode? Just wondering since you are getting such different results with no physical changes other than pedal input. Also the would expect that if something were wrong (boost leak, timing etc) you would have a CEL by now. But if the ECU is getting a bad input from the pedal it may have no way of knowing.
Wag0n
40
Do you know what the GM part number is for the new pedal? I might order it and install it myself. Since there's no codes or anything, it won't be covered under warranty. I've already had the car in for service in the past and it performs within GM's tolerance levels.
Notveryfast
1987 Regal GN, 2019 Regal TourX
93/91 shouldn't make a difference like that. Not 2 whole seconds, at least. Half of the states don't even offer 93. I live in CA, where all we have is 91 at the pump. I'm not running an 8 second 0-60.
D2R
898
Michigan
2019 Regal TourX Essence
Can you ask the dealer to read the signal from the pedal?
I mean, if it is acting like how you described, the pedal may not be sending out the correct signals.
Wlepse
747
NNJ
Check out this thread: Warranty ?
According to the thread if it applies you should see it listed for n the Buick app.
Wag0n
40
I've had it in before and everything is within GM's parameters, there is no warranty for for them to perform without an engine code or obvious problem. GM doesn't consider an 8 second 0-60 a problem.
D2R
898
Michigan
Tell them a 250 HP & 295 lb-ft does not need 8 seconds for 0-60 and threat them with lemon law?
L J
580
Regal TourX
Maybe your ASS is slow...
My ASS slowed me down until I made iit think the hood was open.
Wag0n
40
I have a defeat device plugged in to the hood sensor. I have automatic stop start disabled and it's one of the best mods I've ever purchased.
L J
580
Regal TourX
I assume your not power braking it while WOT for just long enough... so it doesn't dump the boost on the Typhoon..
I have learned the lazy tranny on TourX requires you to WOT early, to make it know your serious.
Wag0n
40
I assume your not power braking it while WOT for just long enough... so it doesn't dump the boost on the Typhoon.. I have learned the lazy tranny on TourX reguires you to WOT early, to make it know your serious.
I am launching the car in the best possible manner to get it to go. There is a clear drop in power after 40 mph that can be felt. But no codes or anything else. Nothing to point to a problem.
Wag0n
40
I'm going to order the 84478060 pedal shown below. Only $38. Other than replacing the pedal, does anything else need to be done? PCM reprogramming or is it just plug and play?
LLninja
Greenback Troll #1
922
251
Illini country, surrounded by bean fields
2018 Buick Regal TourX Essence
Too bad we don’t have a boost meter on the turbo. I’m wondering if your turbo might be fried. Back in the 90s I was test driving several Turbo Thunderbird SCs (before buying a Toyota Supra) and the acceleration varied a lot depending on how good or bad of shape the turbo was. With any Turbo, if you drive it hard, it’s best to let the turbo cool a bit with the engine idle or driving city traffic before shutting the car off. Otherwise you run the risk of melting the turbo.
So have you ever driven the car hard and shut it off immediately? Do you habitually drive like Jeff Gordon? For me, my TourX has plenty of oomph (tested when we were test driving the car) but I typically drive it like a grandpa so I have less worry about frying my turbo.
PS, I’m guessing replacing your pedal will be a wild goose chase, but who knows, maybe you’re right.
Wag0n
40
The car has always acted in this manner and I bought it brand new. It's not every day I go test the 0-60. The power is definitely not consistent. It's a daily driver, if I need to go fast I'll drive a different car. But I'd still like it to be somewhere in the 6's for 0-60
LLninja
Greenback Troll #1
922
251
Have you tried manual mode so you can keep your RPMs up and pick your shift points? This high end speed lag certainly could be your turbo not kicking in like it should. Then again it could also be that the car is a 4 banger, and can’t compare to another fast car with a v6 or V8
