Wiper arm removal
myrobertp
San Antonio
Buick Le Sabre
Does anyone know how to remove the driver side wiper arm on a 1999 Buick Le Sabre? Mine has a little metal tab sticking out of the left side and a tiny screw head on the underside of the arm. Must this be removed to get the wiper arm off? :confused:
imidazol97
Top Dog
1,501
36
48
Raise wiper arm up off the windshield a good distance. You can then pull the little metal tab and rotate the "catch" out that holds the arm up off the windshield. Then you'll be able to pull on the base of the wiper arm and wiggle it up off the splines. The little catch takes the spring tension off of the axle and splines.
Good luck.
Pedal Commander
