Won't start
Dawgfan
Verano
I can drive my car to the store and come back out it won't start. If I let it set for awhile it will go again. What's the problem?
240
Are you saying the engine will not turn over, or if the engine is turning over, the engine will not start??
Zeroboostbuick
251
S.W. Ontario Canada
In your other post you said you replaced the camshaft position sensor because you had a code for it.
Did you get a OEM cam sensor or a aftermarket one ???
Would be nice to know the actual Engine Code you had.
Dawgfan
Verano
P0010 was code. Got part from Autozone.
240
I assume from the info provided so far, that the engine starts and idles normally until you put it in gear, then it dies? The Cam Position Sensor "CPS" will not cause an engine to not run/die when put into gear, but may cause some hesitation upon acceleration. You need to take that thing to a shop that can actually diagnose the problem!
Zeroboostbuick
251
S.W. Ontario Canada
I think P0010 is for the Intake Camshaft actuator solenoid. Which is not the same thing as a camshaft position sensor.
