XM radio no signal
Thread starter #1
Schisslerm
2015 enclave
Hello. We just purchased a 2015 enclave with 54k miles. XM has no signal. Called Xm and they said it’s not an Xm problem because we have no signal or sound when in preview channel. Can anyone give me some advise? Is this a warranty item? Thanks
Thread starter #4
Schisslerm
2015 enclave
Warranty, check with GM or dealer depending on what is the real problem.
Here's a link on the forum of the same symptoms.
Xm satellite radio reception problems
Here's one repair on this issue.
Enclave XM Signal Loss | Buick Enclave Xm signal Fix
Ok just tried to release the yellow antenna plug and first of all it’s in an awkward position but I tried to release the “tab” but unfortunately Someone must have already tried because the tab is broken off. How can I get the yellow plug off now? Please help
1,377
353
The only thing I can suggest is to use a pick to depress the tab. Most hardware stores have, automotive parts stores might. Thick paperclip in a pinch could work.
KevinJ
Contributing Member
192
33
Ohio
I usually check out Harbor Freight when I need a tool that will be rarely used.
Or an odd type of tool to be used for something it is not really intended.
They have lots of those "odd" type tools at cheap prices.
I also buy cheap "sacrificial" tools at Harbor Freight, if I need to modify one for a specific one time use.
Just think outside of the box when wandering the aisles....
And I bet you end buying more than the one tool you went looking for..... At least I always do. :)
Thread starter #7
Schisslerm
2015 enclave
Ok guys so the yellow antenna tab doesn’t have a tab on it and it spins around. I can’t get it out. Anyone help?
1,377
353
These should be push on pull off, don't quote me on your unit, but the other GM I've seen have been. Can't see what is happening, but these are the instructions from the link.
Locate the XM Module (it will look like the one in the image), and unplug the yellow connector by pressing the clip release on the back of the connector and pulling down.
04813d_2a079020d0374f11b9e58c017d961e63_mv2.jpg 04813d_8e5f178ea8974d8ea8d14d7907e2f11c_mv2.jpg
